NOTa belt sander
A belt sander is designed to make surfaces flat...not good for a curved boat bottom. Use an orbital sander, preferably an ocillating type. A dust bag attachment will eliminate toxics. Speaking of...use adequate protective gear (goggles, respirator (NOT a cheapo paper mask!), tape your sleeves, etc...). Copper oxide is nasty stuff. As far as your paint, you can get much info from the forum archives. West Marine has good info in their catalog. Find out from local sailors what paint works best in your home waters. Different paints behave differently in different water. You also need to paint according to the type of sailing performance you desire, how often you haul, how much you want to repaint, $$$, etc. Like I said, search the archives for all the straight poop! I hope this helps!RichardH23 "Invictus"
