Sand blasting will open the porosity between gel or resin and the matting layer underneath the gel .... and makes the subsequent (osmotic) blistering worse than before. Suggest you use crushed walnut shells or 'baking soda' for the blasting.
The compressor really has to be matched to the blasting device ... usually 10+ scfm at 100 psig. for the small blasting units, or more.
