sandblast the hull
billA
Mar 9, 2005
6
- - Amityville
I have a 1979 Oday 23 I the bottom paint is flaking and I asked my boat yard to sand blast clean the hull and bottom baint so it is all clean, Do I need to epoxy the hull befor paint , the guy in the yard said the boat doesnt need it how do I tell? And what happens if he is wrong
W
Warren
Sand Blast!
Don't sandblast the hull.....If you must "blast", use higher pressure water. I don't even like that. Fiberglass is porous and solf, easy to damage. A hand scraper to remove the loose paint. Don't like for perfection in an old boat. Get the "loose stuff" off and roll on a coat or two of fresh paint.
Jun 6, 2004
300
- - E. Greenwich, RI
Blasting the bottom...
...is okay to do, just don't go through the gelcoat. Barrier coat after that and then bottom paint. If you blast the bottom you need to do the barrier coat. If I were you I'd find another yard guy who knows what he's talking about. If you want to avoid the high cost of blasting/barrier coat, just go over the bottom with a random orbital sander and then fresh bottom paint. Cheers, Bob
Mar 28, 2005
92
Oday 25 Stony Brook
Power Wash
I just getting the boat delivered to my house in a few days and when I inspected it they where a few lose spots in the bottom paint but good in general. So power washing will remove the loose paint and a little sanding will do the rest. Then the bottom paint will go on.
