Greg, A club mate used the system last spring. It did the intended job. It was a slow process. Used around 3000lbs ( 75bags) of sandbox sans on a 33' boat... HINT.... the sand MUST remain dry for this to work. It is a Venturi type operation. The second you let off the trigger, residual water travels down the pick-up tube and into the dry sand... The solution is to keep the media bucket above the wand level..Hello all
I see these sandblast kits you can buy that work with a pressure washer. Cheap and look like they work but do they??
Thanks
Greg
Generally, anything I see in an informercial or if it says "As Advertised on TV" is not something I going to waste money on. That includes YouTube commercials.Interesting..... that’s a lot of sand and at 4.50 a bag could be pretty expensive! the infomercial makes it look great. I’m not looking to take all the way off, just to get any loose paint off.
Thanks
Greg
Not really that expensive, compared to what a boat yard would charge.Interesting..... that’s a lot of sand and at 4.50 a bag could be pretty expensive! the infomercial makes it look great. I’m not looking to take all the way off, just to get any loose paint off.
Thanks
Greg
