San Juan Islands
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
We've been cruising the San Juan islands all week with 3-5 other boats. Mostly it's been Deborah and I in Verboten, Bill & Sue in Windsong (Mk I Capri 22, WKSR), Scott S in a Catalina 22 Mk II, all sailing in company. In addition, Scott R has joined us most evenings in his Catalina 22, and Lou and Rochelle have met up with us once in their Mac 25. Surprisingly good wind means way less motoring than last time we were here.
While there have been a few minor mishaps, mostly it's been great. I've had a few "issues"
The mainsheet block came off the traveler when I raised the sail the 2nd day. My guess is I hadn't done a good job of tightening the screw. Unlike the viagra commercial, I didn't have to use a lifejacket strap to put it back together. Just some mighty quick work to get the pin in with a somewhat flappy sail.
The second day was also when I discovered a leak in the forward locker. We kept finding water in the portapotty well which I initially thought was condensation from the ice chest. Turned out it wasn't. The @!@#$2 through hull for the old paddle wheel is leaking - apparently the 5200 or whatever they use to seal the actual fitting has gone bad. I patched it up as best I could with some MarineTex that Scott R had along, but it's still leaking about a cup a day. Grrrr.
Anchor dragged as the tide came in and the wind came up in Shallow Bay on Sucia Island. Relocating and resetting was a pain because the Admiral and I were not communicating well. Second set held, which was good, because the wind was blowing like snot and we were sailing all over the place.
Dinghy failed to start the morning of the 4th day, figured out that evening that it had run out of gas at about the same time I shut it down. Whoops.
Yesterday (Day 4) I had the most worrying failure. In the middle of our sail from Shallow Bay to Reid Harbor on Stuart Island my chart plotter died. Borrowed a multimeter from Lou and figured out that one of my crimped connections had come apart (I'd fire the electrician if it wasn't me) which had blow the fuse in the breaker panel. Luckily I had a spare fuse.
No major issues today.
Poor cell signal here so I'll have to post photos tomorrow when I have better throughput. :)
May 16, 2012
90
Catalina Capri 22 IL
That sounds like a usual trip. Things go wrong and its about finding a quick fix!
I found that the Capri hull is so thin that you don't get a good surface area to properly seal a through-hull. I took a piece 3/4" plywood about 6" square, cut a through-hull hole in the middle, shaped it to the interior of the hull and epoxied it into place. I then re-sealed the fitting and never saw a leak again. Its a cheap fix.
I assume you had a backup plotter/GPS unit?!?
May 3, 2008
252
Catalina Capri 22 Half Moon Bay
Despite the minor "issues" it's sounds like a great trip!!
Looking forward to the photos!
May 23, 2007
1,306
James, welcome back!
My through hulls have what looks to be 1/2 inch backing behind them. Couldn't say who put it there but I'm sure it's soggy now. Grr.
Spare GPS was my phone or my laptop, or paper charts which I had along too. Not good enough to . The other guys in the flotilla had gps as well, just not depth sounders from what I could tell.
j
May 23, 2007
1,306
Today's sail from Roche Harbor to Friday Harbor was a slog. It was nice when we left Roche but kept getting rougher and windier as we motorsailed towrd the north end of Speiden Channel. By the time we were in San Juan Channel the seas had built to 2-3 feet and I had the motor come out of the water, or nearly so, once. The turn toward Friday Harbor put our nose right into the wind so we decided to drop the sails and continue under bare poles. That seemed better and the fact that there was less fetch and adverse current as we got closer to our destination helped.
Forecast for tomorrow calls for 10-20Kts again, with wind waves of 1-3 feet. About half of our sail is inside the San Juans, so protected, but we do have to cross Rosario Strait in the afternoon. We may go as far as Spencer Spit and lay over there if it's too bad.
So, no pictures today, too damned windy and wet! But here's a few from the rest of the trip.
Capri 22 #421 (Windsong) & Catalina 22 in President Channel
Nice view - Shallow Bay, Sucia Island
Roche Harbor Resort sunset
Chris
May 23, 2007
1,306
Here's what you get when you put 6 adults in the cockpit of a Capri 22 . . .
We had a great sunset in Friday Harbor
shnool
Aug 10, 2012
556
WD Schock Wavelength 24 Wallenpaupack
Sounds like an epic trip to me!
Don't get me started on the Viagra commercial... So much wrong with that commercial...
I look forward to more pictures though!
May 3, 2008
252
Beautiful pic's! ...looks like it was a fantastic trip!!
Looks like great sailing and amazing sunsets!
May 23, 2007
1,306
Safely home from the San Juans tonight. Verboten is dirty inside and out! Managed to trash the windex when we lowered the mast, otherwise a smooth finish to the trip. Bill V, who I don't think has re-registered here yet, and his wife Sue are great fun!
Kunzig
Jul 3, 2013
88
1013
Chris - we are starving out here for an adventure like that! More photos, if you got any - when you can, thanks! Congrats on what looks like a great trip. Have you enough water at the lake yet?
Jul 3, 2013
107
1258
Sounds like you had a great trip!
A few years ago, I spent a week in a waterfront rental house near Roche Harbor (home of the "Phecal Phreak"). Did not get to do any sailing, but did get some kayaking in.
The San Juans are a beautiful spot to hang out. I envy you for being able enjoy them from time to time.
Lake Albany will seem kind of boring for the next few sails!!
