San Domingo Creek (back door to St Michaels)
292
Hunter 49 123
How is the anchorage at thee nd of San Domingo Creek and ho far is to dingy to the town? Any land/watermarks to go by? I can see Red "14" PA in my chart book, is this the last nav aid in the creek? I alway use the Miles River but my schedule is to go to Oxford after St Michaels and later Cambridge. Thanks, Velero
Ross
Jun 15, 2004
14,693
There is a source for better charts
http://ocsdata.ncd.noaa.gov/BookletChart/AtlanticCoastBookletCharts.htm
Look to chart 12270 page 20
Jun 4, 2004
292
Hunter 49 123
Local knowledge
Thanks Ross for the source, but I have a couple of charts/books and they all have the same scale. I was I looking perhaps for some local knowledge or someone that has been there in the last few months.
velero
May 24, 2007
49
Catalina 350 Herrington Harbor
San Domingo Creek
Valero:
On your way up the San Domingo, there are two side creeks off to port. Once you get past the first one, the channel narrows up but is passable. I wouldn't go past the second side creek. In the area between the side creeks, the San Domingo is wide enough to anchor one boat across. I prefer to anchor in the wider areas where the side creeks join in. Any place along here is only 1/3-1/2 nm from the landing on the edge of St. Michaels.
Set your anchor well! Holding is not particularly good along here. If you are expecting a wind shift, you might want to go with two anchors.
Gary
Even Keel II
Dec 24, 2003
233
- - Va. Beach, Va
Velero,
"Even Keel"'s info is good., although anchoring just inside the 2d creek on the left is also OK. The last time I was up there, I found it necessary to anchor there because the remainder of the anchorage was full of boats.
