Hello all first post ,,,any comments. About buying a salvage Beneteau. She went under during Katrina and has been brought back to operable condition . Engine rebuilt and seems to run smoothly no shaft vibration. Some electrical problems of course ,with lights ,wires are hot fixtures are shot. , frig compressor probably ok but motor is frozen.stove and propane system removed but seems complete.Interior table missing.sails not original and not new but adequate. New macerate pump not installed, port side toerail missing ,lifelines need replacing abut material is on hand, some of the bolts look to be galvanized and stainless,easy to fix but worrisome as to how/why they got there, am I correct in assuming this boat has a bolted on cast iron bulb keel, boat does not appear to leak inside. Bilge pump hooked to a water hose hanging out the hatch ,is that a factory install ?
Can I tell enough about the hull below the waterline diving on it ,,I am a certified diver. At the price he is asking I will have to pay for a haul,out.
These boats on the web look to be in the $40k range ,,owner just wants to get loose ,as he is leaving the area. Askin $8k ,,boat is not trashed but needs work. I have a good network of folks with skills ,and I am pretty handy myself. If I spent another $8k after i bought it it would still be adeal.Boat can be sailed today ,,if you don't need lights or gauges. It almost looks too good to be true ,,and I am waiting to see the paperwork ,,,all opinions and comments appreciated . ;{)
Keith Wells Biloxi
Keith Wells Biloxi
