Along the same lines as the flushing engine thread, I was curious to know if there is something other than Salt Away to flush out an outboard? I know the manual recommends fresh water after each use, but that is not always possible. I am sure there is a build up of salt in/on my water pump and cooling coils.Is there anything, maybe that can be used in conjunction with Salt Away, that will help break down the salt deposits in my cooling system? To the best of my knowledge, my cooling system is working fine, I just want to make sure and keep it that way.Thanks of any inputs.
