I changed the zinc anode in my generator. It appeared to have salt buildup on it. I have Ts on my raw water through hulls and flush both diesels with 5 gallons of fresh water each spring after the boat is hauled. I am thinking I could just add this to the fresh water in my 5 gal bucket when I do the flush. It will be sitting for 6 or more months so maybe just fresh water flush is not enough.
Have any of you used Saltaway ? Does it work ? I emailed the manufacturer to ask about leaving the product in the engine over the summer. The literature they have indicates it has corrosion inhibiting properties as well.
Thanks, Bob
Thanks, Bob
