Hunter Legend 40 Sails
I've recently purchased new #1 (155%), #2 (140%) and a full-battened main for my 1984 Hunter Legend 40. The question you should ask yourself is, what do I plan to do with my boat? Are you pretty much a day-sailing cruiser, distance cruiser, or are you going to do some club racing. And if you do, how competitive do you want to be.My first investment was to get rid of the Hood Seafurl 915 LP (continuous line), and replaced it with the Hood SeaFurl 5 (Model 325 3/8). I have the deep keel model (6'6") and the tall stick.The 3DL priced out of this world North Sail was not realistic for the club racing at the level that I wanted to compete. The North 3DL while a cutting edge sail, is like giving a scapel to a lumberjack. Meaning, most racers won't sail to the level that it is intended. So I stayed within my budget and went with the local loft -North's 4.7 oz. PremDac (695 sq. ft) 155% Nordac RAce AP #1. The max apparent wind speed is about 20 knots. It came with the sail numbers, telltale windows, 3 trim-stripes, crosscut layout, high modulus leechline and footline, spreader patches, "steering" telltales, 3 draft stripes and a zippered turtle bag. It cost me about $ 3,000. You can get a more economical sail (without the little "blue logo" for several hundred dollars less at several lofts in the northern gulf states.My main was a North 8.8oz with full length battens Dacron sail. That was in the neighborhood of $ 2,800. I have one reefing point in this sail. I have a flattening reef also. My #2, North 140% 8.0oz Seatec (Dimension) with crosscut paneling was the typical North Sail construction with bigger patches and to the North Standard. There is so much confusion with sails. The sailmakers relish in it. They are like tire salesmen. Their must've been about 25-30 different sails for each of the above in the North product offering. If you contact me, I'll give you some alternative lofts that you might consider.My sailmaker is of the opinion that a 140% is a perfect sail for my boat.I use a "poorman's" lazyjack that I use only when the main is to be lowered, then removed to a cleat on the shroud line.My North Sails I believe to be constructed a little bit better than other. It may just be between my ears. But the sailmaker is local (most important!!!), in case the cut isn't right.By the way, I've been kicking butt with this tired old lady.
