J jim slagle May 13, 2009 #1 What is the best method of fixing a leaky bolt on the ceiling of the cabin. Handrail bolt, I think.
Bad Obsession . May 23, 2004 3,319 I'm in the market as were . Colonial Beach May 13, 2009 #2 Take the bolt out and then clean the hole. Finally, go back and rebed the bolt when you put it back in.
S Steve Dion . Dec 2, 1999 15,184 Hunter Vision-36 Rio Vista, CA. May 13, 2009 #3 I would recommend that you remove the hand rail. You may need to caulk under the hand rail or fill the hole with caulking. Once you determine where it is really leaking you may have a better idea.
