Sailmaker Due Diligence
Mark, The first thing I do is ask you a set of questions that will give me a good idea what type and frequency of sailing you do. Racing or cruising, day sailing or blue-water etc. This will help me recommend the type of sail that will best match your needs. We would go over the specifics of the proposed sail in terms of material, batten configuration, reefs(1,2, or 3?, sail numbers,etc. and answer any questions you might have. Once we have agreed on a price I assemble all the information I need to build you the perfect sail. I like to go to the boat and get a fresh set of measurements. If the boat is not available you can use the old sail as a basis for the new one. We then design and build the sail. If possible I also like to install the sail to make sure that everything fits just right.Thanks, Bill ColomboDoyle Sailmakers
