Thank you, dLj for your comment. Yes, "delivery" is my first priority, it is how this venture/assignment started, but I wanted make it in to an adventurous voyage with certainty of safety. I will have time to go through the boat and equipment, etc. during the handover process with the owner/seller a day before I begin the trip, hopefully a short sailing in the bay during or after the handover.
You are going to be checking out the boat, how it sails, all the systems, preparing for the trip - all in one day? That is a very short amount of time, in my opinion. There are a lot of things to inspect and understand about a new-to-you-boat....
I will use the first day as you suggested to get some feel and comfort level of the boat as well as the capability and measuring an average distance/range of travel per day, then decide the ports we selected are appropriate. I don't have any plan to do any overnight sailing. We will pull in to a port every night, so PaulK doesn't have to worry about that - thanks for your concern thought.
I am a strong supporter of only doing what you feel comfortable with.
I do have one question of a dingy. This boat is supposed to come with an inflatable dingy.
What do you know about the dingy? Do you know if it's PVC? Hypalon? I'd recommend finding out ahead of time and picking up a patch kit for the correct dingy material.
Q1: how do I inflate it and how long does it take to inflate? Do I need a specific pump to inflate?
As others have said, there is typically a pump that comes with the dingy. - could be electric, could be manual - often has a special fitting that goes into the tubes. How long it takes to inflate depends upon how big it is and how good the pump is. I would definitely have on my check list that you check to make sure the correct fitting is on whatever pump comes with it actually fits the fitting in the dingy. I would also check to make sure each connection works.
Q2: Do I need it to get to the dock if I moor the boat at a port?
Are you planning to pay for slips in each of your perspective overnight harbors? Have you budgeted for that? If that's your plan then you won't need to dingy in. If you are planning to get mooring balls, or anchor out, you'll need a dingy.
Part of the first day inspection/handover would be to pull out and measure your anchoring system. Does the boat have all chain? All rode? Chain and rode? Exactly how many feet of what? How is that anchor rode measured when setting it out?
Q3: Do you advise to tow the dingy the whole trip? Thanks,[/QUOTE]
I never advise doing that, however if you are only sailing 6 hours or so a day, you could. You do really want to inspect the attachment points of the dingy to make sure they can withstand the towing. If they look worn or iffy - I'd put the dingy on deck.
Just my 2 cents worth...
dj
