Sailing boat speed on a Hunter 49 or 50
Jul 19, 2010
31
Hunter 33 Marina Del Rey
What kind of boat speed are you getting when you are sailing? I think I am sailing slow, but I am not sure why.
We do about 8.0 kts under power, but it is rare for us to get above 5 when sailing. (In mast roller furler)
Sep 20, 2006
2,952
I can get 6- 6.5 knots in 12- 15 knots wind in my 33 and towing a dinghy, so you should easily be above 7 if not 8 knots. What wind conditions, sail configuration, point of sail etc. Give us some more info and can help.
Mar 20, 2012
3,983
what is the wind speed that you are sailing in?.... what size of jib/genoa do you have?..
given that you have wind and the proper sail area for that wind, its all about sail trim after that. the sail trim can either be done using the control lines on the boat or it may have to be done by the sailmaker, depending on the conditions of the sails....
to push the boat to maximum hull speed like your motor can do will take a good wind or lots of sail. but you should be able get within a knot and a half fairly easy...
Rick D
Jun 14, 2008
7,188
It may be the nature of where you are sailing. Santa Monica Bay is notorious for light air conditions; 7-12 knots. You probably need 18 knots to get to hull speed.
Jun 5, 2004
485
Hunter 44 Mystic, Ct
Sailing Speed
Like others have said your speed is dependent on several variables. Just as a rough reference point however, it takes a good 15 knots + of wind to get our H44 up to ~ 6.5 - 7.0 knots on a beam reach. I have a fixed 3 blade prop and in mast main. The performance of the main is very sensitive to the outhaul position and under the conditions above we have a pretty deep belly in the sail.
Mar 5, 2013
50
Hunter 45CC Lake Erie, Sandusky Bay
I'm in a H45 in main and just small jib. Reaching in 10 to 12 knot wind I can do 5 to 6 knots. In 13 to 18 knots I can do 7 to hull speed 8.3, no surfing. What condition are your sails in?
Sep 20, 2006
155
Hunter 49 Mystic CT
On my 49 I expect to do about 50% of apparent wind speed. I honestly don't think you could do much better on a cruising boat.
Roller furled main, 110 jib 4 bladed Variprop
Jun 1, 2009
1,851
Hunter 49 toronto
Easily 8 knots
On my 49, I'm up to 8 knots in 12 knots TWS without a sweat. With 15 knots of wind we are doing 9 - 10 knots
What I did was have a really nice #1 Genoa made, which makes all the difference
The boat came with the self tacking Genoa, which I've used twice. Way too small
I have convinced other 49 owners to do the same thing, and they can't believe the difference.
I also have a 4 blade variprop
Feb 3, 2014
94
Hunter 44 aft cockpit Miami, FL
On my 49, I'm up to 8 knots in 12 knots TWS without a sweat. With 15 knots of wind we are doing 9 - 10 knots What I did was have a really nice #1 Genoa made, which makes all the difference The boat came with the self tacking Genoa, which I've used twice. Way too small I have convinced other 49 owners to do the same thing, and they can't believe the difference. I also have a 4 blade variprop
what is the size of your #1- Genoa, please?
Jul 19, 2010
31
Thanks for all the responses.
In relatively small seas and 12-14 kts of wind, we are doing 5 kts or slightly faster, peaking at 5.5. As the wind comes up, I find that we heel a lot more, but are not going a lot faster.
I thought all the Hunters had a small headsail. The H49 comes with a 110 genoa. Our sales are far from new, but they are not in bad shape.
(The bottom is clean).
I appreciate Marc's comment. I tend to keep my main pretty flat. I am will leave it a little fuller next weekend and report back.
Thanks again.
Jun 1, 2009
1,851
Hunter 49 toronto
My #1 genoa
Call Greg at quantum sails Toronto
He has the specs on the #1.
Anyone who owns a 49 and uses the self tacker is really missing out on how well this boat performs.
