I thought it might be interesting to see what various people here think about a Saildrive power system vs. a conventional stern tube shaft drive.
Not that any of us that already have a boat can do anything to change what we have, but what do you see as the pros vs. cons of one over the other?
Not looking to start a controversial topic, but more of less an informative disussion of the two distinct and different methods of power and propulsion transfer.
Is one any more efficient over the other? What about cost? Just curious to see what everyone's thoughts are.
My first advantage that I would see with the saildrive would be the elimination of the need for shaft to engine/transmission alignment. When it would come to major work, can you split the "outdrive" portion with the boat still in the water to access internal components?
I have a transmission on my boat, so if I need to work on anything from the shaft forward, I have 4 bolts to break loose to allow me to pull the transmission and or the engine and can leave the boat in the water.
