Anyone have one or knows if the procedure to change the gear oil is similar to that of an outboard lower unit, i.e., drain and refill from screw holes in lower unit?
in, I think, Boat Works, on replacing the seals in a saildrive. It also covered the oil change and, as I recall, it was the same as an outboard with the same "test", i.e., if the oil is milky, change the shaft seal.Good luck.
Chris -saw the Boat Works article which emphasizes the seal and shaft mechanism but doesn't expain the lube oil other than to say refill...The link you posted ConchyJoe is excellent but the saildrive my son has is below the hull and therefore a different animal so still looking for advice if anyone has info on the proper way to refill.
I've always had "problems" with this concept of Saildrives. 1. For the builder or manufacturer-- easier and cheaper to install.2. For the owner -- harder and more difficult to maintain.What part of this equation am I missing?The "seal" between the hull and the pop-through intrigues me still.Give me a simple stern tube and packing gland, dripless, regular or PSS, and I submit that simpler may be better in the long run.Just a thought.
the manufacturers put a "water in sail drive" warning indicator and there is a place for the idiot light on the engine console. Perhaps they are trying to limit their liability?
Saildrive has no prop walk, which is both a plus and a minus.http://www.cruisingschool.co.uk/home/icc/prop%20walk.pdfIf you are good at it you can use prop walk to aid docking.http://www.cruising.sailingcourse.com/docking.htm
I have a Volvo saildrive, but I don't think this job can be that different. The drain is located at the bottom of the drive, and therefore cannot be accessed unless the boat is hauled. It is filled, after replacing the drain plug, through the "dipstick" hole, behind the engine. I do mine as a part of the annual haulout.Hope this helps,
