Saildrive boot relacement
rgreno
May 31, 2010
3
catalina 250 penticton
I have to replace the rubber boot around the leg on my yanmar sail drive but can't seem to find a applied. Catalina said to contact yanmar and yanmar dealer doesn't carry them. Also any suggestion on the type od adhesive the contact cement I tried did not work before.
Jul 27, 2011
5,137
Bavaria 38E Alamitos Bay
I resealed (re-attached) mine using the 4200 adhesive two years ago; still holding.
rgreno
May 31, 2010
3
Hi John who makes 4200 and where did you find it? Thx for the info.
jrowan
Mar 5, 2011
1,294
Say, I'm just curious about the longevity of saildrives. Why are they made of an aluminum housing? Doesn't this pit & corrode like crazy in salt water? I assume its to save weight & cost, but I always thought it was a good thing to have weight down low for ballast. the cost savings to produce saildrives must be more then offset by the maintenance factor. Also I guess u can't use copper based ablatives as they would cause corrosion, so what do u use?
