Sailboat shopping
Danno1
Jun 10, 2014
2
Catalina 27 Toledo
Hi,
I am thinking about buying a sailboat for the Tampa Bay and island hopping the keys. I am leaning toward a Vision 32. Any Thoughts.
May 25, 2012
4,338
buy a fresh water only vessel here on the lakes then take it down
Nov 8, 2010
11,386
Indeed our sweet water boats will (year for year) have less rigging wear, UV damage, and use/wear in general. But you have to figure spending $6-8k getting it down, which is 1/3 to 1/4 the asking price of a Vision 32. Personally, I'd find a good local one.
Rick D
Jun 14, 2008
7,207
Great boat; had one for nine years. See the owner reviews on this site.
May 24, 2004
7,235
CC 30 South Florida
Good boat for your purpose. Buy local, check out the cost and availability of marina slips.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Recommend a larger boat, something closer to 40'. There is a lot of ocean sailing between Tampa and the keys. A 32 will do but you will be happier with a 40. Not only is a 40 more comfortable you will be cruising closer to 7 knots vs 6.
Oct 31, 2012
465
Hunter 2008 H25 Lake Wabamun
Shallow waters along the Gulf coast and around the Keys would lean to a shallow draft or better yet retractable keel. The Seaward 32 ( or similar) is a good choice.
May 12, 2004
1,505
Don't know anything about the V32 except the telephone mast. Have done that trip many times on my h30. Many more times on 40+ boats. More comfort in a 40 footer to be sure. If $$$ is not an issue, go bigger. The deciding factor is draft. Four feet or so is good. Think Morgan 41 Out Islander. Five feet is OK. Six is limiting.
-na -NA Anywhere USA
Should you have to pull the mast off, suggest let those who know what they are doing or taking the mast down do that for you. Sometimes they are stuck and trying to pry it loose, caution is recommended.
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
Not necessarily. You can "hop" down the coast to Naples, then take off from there. Don't have to aim for Key West. Crossing Florida Bay is tricky b/c of its shallowness; seven feet in places. Might need a boat (large or small) with a shallow draft; many folks have done in it retractable keel/centerboard boats. Suggest you plan your route, then pick a boat. Right tool for the job, etc.
Gunni
Mar 16, 2010
5,937
If I were buying a boat for that area it would be a small multihull. That opens up the 10,000 islands and much of the everglades coast plus the back country of the keys.
