More on vang and mainsail trim
As mentioned in the previous posts, as the vang pulls the boom down, it also pulls the clew of the mainsail down, and tensions the leech. It works the same whether the mainsail is loose-footed or not. Going downwind, this downward pull stops the boom from rising and presents the maximum sail area to the wind.The vang also has an effect when going upwind, but is usually overridden by the downward pull of the mainsheet, especially when sailing close-hauled. A tight leech is harder for the wind to deform so the wind is deflected further aft as it passes over the mainsail. This creates a force on the sail that tries to turn the bow of the boat more into the wind...an effect called weather helm.A tight leech is not the only cause of weather helm, but in my opinion it is one of the most significant. A little weather helm is good because it gives the helm some "feel", creates hydrodynamic lift and forces the boat to turn up into the wind automatically and stop if you lose control of the helm. Too much weather helm creates drag and can slow the boat because the rudder has to be angled more than it needs to be in order to maintain course.An adjustable backstay is very useful as it does two things to the mainsail at once. Tensioning the backstay bends the mast like a bow, i.e. the masthead moves aft and the middle of the mast moves forward. Moving the masthead aft eases leech tension, which deflects airflow over the mainsail less and decreases weather helm. Moving the middle of the mast forward tightens and flattens the mainsail, reducing power. The backstay is the primary adjustment for reducing power and heel when racing upwind in heavy air. When cruising, reefing is probably the more prudent way to reduce power and heel, but a lot will depend on your experience, the sea state, weather and other conditions at the time. Good luck!PeterH23 "Raven"
