Sail Size
Mark Sanford
I am considering getting a smaller hanked-on head sail for my H23 on those days where the wind is too strong to sail comfortably with a reefed main and 110% jib. I have tried sailing with reefed main alone which will allow the boat to sail on its feet but it does not allow me to point into the wind at all. I was thinking of a smaller jib, maybe 70-80% of the fore triangle size for those windy days. Has anyone else tried this? If so what were your results? What size of jib would you recommend? Thanks for your opinions. Mark
John Sims
Yes
Mark - I believe a 70% jib would be an excellent choice for those over 15kt days if you do not want to go to the extra expense of installing a jib furler/reefer. I thought about doing the same thing myself but opted for a CDI furler and new 130% reefable jib, that way I feel like I am ready for almost any situation. So far it has worked great! John, Pensacola, Fl
Scott Davis
Windy Days
I also know what you mean about those windy days where the 110 and reefed main are just not quite enough. I like to think, I am an all weather sailer, but there comes a point where you really shouldn't be out there. I can sail ok with the reef main and 110 up to about 20 kts, after that I don't think anyone really should be out there sailing anyway. The H23 although built very well, are not rigged to handle high winds and heavy seas. If you have ever seen a REAL off shore sailboat you would notice how much heavier the rigging is to take the bad weather. The point I wanted to make is on those real windy days, you really should stay home and watch football. As a 20 year Vet in the Coast Guard we all would like to see the game too and not go out in terrable weather to find you. I have been in some weather that would blow your mind in both ships and sailboats. Be carefull out there and know your limits. Scott Davis H23 "No Alibi"
Darrel
When its windy
I agree with Scott. When the wind is to strong for the 110% and reefed main it probably time to head in. If you are a racer then a 70-80% might be a good sail to add to your inventory. You might use it when the wind is 18-20 kts. Botom line is have fun and be safe.
Apr 19, 1999
1,670
Don't quit just yet
I agree wholeheartedly that you should not be out in conditions that will put your boat and crew at risk. However, heading for home is not the only option when the boat becomes unmanageable under reefed main and 110 jib at 20 kts. If you are not close to shelter and your motor quits, you will have to sail. Assuming you have depowered the sails as much as you can, the next thing to do is drop the jib. In 20 kts of wind, the H23 becomes so docile under main alone you can shake the reef out. However, don't shake the reef out if the wind looks like it is going to keep building. Try not to cleat the mainsheet when the wind picks up, especially if it's gusty. Ease the sheet as needed to control heel, especially in the gusts. With a properly trimmed jib, you can ease the main until there is a big bubble in the luff and still have good boatspeed. I have found that excessive heel is the greatest cause of weather helm in an H23. If your weather helm is so severe that you can hear the water roaring off your rudder blade, it's time to ease the mainsheet. Try sailing under main alone sometime when the wind isn't too strong and you will see the difference that dropping the jib can make. You can also have a second set of reef points added to your mainsail. This option has been discussed here in the past and is probably in the srchives. It's a lot cheaper than buying a 70 percent jib, and gives you a third option for sailing under main alone. Good luck! Peter S/V Raven
