Sail shorter distances with wind shifts
Other Catalina 30 Tucson, AZ
Mates: I'm going to do this in 2 parts due to its length. Some sailors could care less about when they arrive at their destination and don't bother with sail trim in the process. If you are one of those guys the following info is not for you but if your a newbie or a middle to back of the pack racer or just someone who wants to beat the cruising fleet to Catalina (ow wherever)then read on. As a cruiser or racer by playing wind shifts you can sail a shorter course. The advantage if your a racer is that 50% of the sailors racing don't understand wind shifts and some of these guys might be in your fleet. First we have to understand HEADERS and LIFTS. Simply put, a header is a wind shift that causes you to sail AWAY from your destination and a LIFT is a wind shift that causes you to sail TOWARD your destination. You can determine either by refering to your compass or by just lining up your bow with a reference point. If your bow falls off from the reference point your being headed. If the bow moves towards or past the reference point your being lifted. Next I'll explain how by playing a simple lift of 20 degrees can save you 25% off the distance you would have normally sailed had you not played the shift.
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
Translation???
So what your saying is that your going to help us learn how to stop the boat from slipping to leeward as we sail (aka: boat actually goes where the bow points instead of a little to leeward)?
C
Chris
Actually...
Actually Don, your simplified terminology only applies to upwind. When sailing to a dead downwind point, a lift takes you AWAY from your destination and a header takes you TOWARDS your destination. (Also assuming you are not running dead downwind.) Chris
May 6, 2004
916
Hunter 37C Seattle
Franklin, not even Don can teach that
He is just going to tell you how to steer a quicker route upwiind with shifting wind direction, while you slip to leward the whole time. Also I think headers and lifts can apply to pickup trucks in your neck of the woods.
Translation
Franklin: Please wait a second until I finish the piece before you assume what I'm talking about. Chris: Your right I am talking about closehauled because I can only talk about one point of sail at a time without confusing everyone. Downwind is a story in itself but wind shifts are a big factor there to. Additionally, downwind is a mirror image of upwind.
Alan
4,174
Hunter 35.5 LI, NY
What Don is talking about is piloting 101 and using the constantly changing wind speeds and direction to give you the BEST possible course to sail. Sideslip or leeway is a design factor of your boat which cannot be changed without major hull mods. However, no matter how much leeway your particular boat makes, you can still take advantage of the headers and lifts to give you the best course to steer.
