sail repairs - sailcare
May 21, 2006
321
catalina 25, 30 montauk / manhattan
have a few needed repairs -
cat 25:
- on the genoa bottom edge of the luff tape(?) has frayed and nearly impossible to feed into the track. in a email from sailcare mentioned that is "difficult to repair". any others have this issue?
- main needs a few broken slugs replaced (sewn in)
cat 30:
- plastic discs for the dutchman keep coming apart and the line has made a small tear in the sail. as read on another post would like to replace discs with metal grommets.
preferences of using a company like sailcare vs a local sail loft? normally less expensive? in my case seems more involved to have the sails shipped than to just drop off. anyone recommend local shop in eastern long island? could also have the marina handle?
thanks!
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Put sail slides on the sail and then you can feed them into the track slot. Just lace them on the sail with some nylon string. Chief
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I've used Sailcare for years and generally like them. Yet I think that their only advantage over a local loft is their cleaning process which I think is superior to what most local lofts can do. Sailcare is also sort of pricey since you also pay for a round trip via UPS. For the simple repairs you describe, I would use a local loft, however.
Jan 25, 2013
22
tartan 3700 northport NY
Jim Reichel at Sailor's Choice in Amityville, N.Y. has been taking care of my sails and canvas for thirteen years. His work is first rate and the price is more than reasonable. He is also a dealer for dutchman products.
Warren's right. I had the same issue with the luff tape on one of our jibs and the local repair loft was able to put in a few feet on new luff tape. Not a big deal at all. Local loft is your answer. For both issues.
