Sail Paint?
Bob Sclater
I want to repaint the logo on my sail. What type or brand of paint should I use? Thanks for your input.
Bob Sclater
Trevor
Vinyl or similar sticker
Hi Bob - I would be wary of using paint; most sailmakers use stickers made of vinyl or similar for logos and sailnumbers. I'd contact a local sailmaker and ask them what they'd recommend. Best, Trevor
Trevor
Jun 3, 2004
275
- - USA
Sailrite Has Adhesive Insigna Material
designed for this purpose that comes in black and white color. It can be purchased by the yard, cut with a scissor and easily installed. try sailrite.com
Jun 3, 2004
275
- - USA
Droop
I vote
I vote with Trevor for Vinyl or similar sticker. Paint will never stick! But good idea!
Droop
I vote
Joe
Jun 1, 2004
8,310
You can order a new one from
the factory, if it's still in business, or from any sailmaker. Do not paint. The logos are printed on a treated, dacron type cloth that has an adhesive backing. After getting the logo lined up you remove the adhesive's paper covering and fix the insignia to the sail. I ordered a pair of red Catalina 27 logos, and two sets of black numbers, from the Catalina factory parts dept. They were delivered in a few days, cost was about $40. And....they look fabulous. I might suggest that if your logo is looking pretty ragged, it's possible that the sail holding it up is probably in pretty bad shape too. If you took it to a local loft, they might freshen up the sail and, at the same time put on the new insignias for you.
Joe
Jun 1, 2004
8,310
Dec 5, 2003
89
Hunter 260 Whitney's Marine, Jacksonville, FL
Is there a service?
Where you can have this done yourself? i.e. Deisgn your own log that you would like on the sail and have them make one?
Dec 5, 2003
89
Is there a service?
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
Sailboat Logos
This company does logos for Catalinas...don't know about others: http://www.sign-mgmt.com/store/
Jun 2, 2004
1,077
Sailboat Logos
