Main, Roller furled 110, Asymetric
The more I learn, the more I am convinced this is the best cruising set-up for one mast.Above 10-12 knots, the 110 is the right foresail for working close to the wind - our 130 is just too much sail as the wind increases, and loses shape as we furl it. Above 15 knots, we are sure glad to have the 110, which can be reefed down to an 85 - again with some loss of shape. But at around 85, with a second reef in the main, we are quite comfortable at 30 knots.Below 10 knots, the large genny is the best sail for close hauled beating into the wind. But I submit that this is seldom needed in the cruising world. So I see the big genny as a racing sail for working to the windward mark in light air. Going to windward in less than 7 knots means the iron genny for most cruising work.Like many good cruising boats, our shoal draft '77 h27 doesn't do well close hauled to windward without lots of rail meat. With just the Admiral and me, 60 degrees off the wind is about as close as we sail. At 60 degrees off the wind in light air, our asymetric is easily as good as a big genny. and as we ease off further, the asymetric becomes much better. (There is no way to sheet a 130 wide enough to keep it efficient on a beam reach.)We find that gybing down wind is much faster than running (which conforms to the advice of most sailing experts.) The asymetric is still a great sail at 145 degrees off the wind.The last point is that both roller furled 110 the asymetric with its sock are easy and quick sails to set. Both can be rigged and ready to deploy at the same time. I almost never hear of our cruising friends changing foresails, even when they desparately need to as the wind picks up. On a recent downwind (gybing) run from Ashtabula to Erie in mounting winds, we just dropped the sock on the asymetric, and unfurled the 110 after the first round-up. We were at or over hull speed the whole time. Our friends accompanying us were struggling to manage their 155, and not keeping up despite a longer waterline.All of our sails are from Doyle. I rate the advice of Greg Koski in their Cleveland loft very high. He listened to our plans to cruise (not race) and recommended a multi year program to get to our current sails. So I recommend working with a knowledgeable saimaker to decide on the right set-up for your boat. We also have a 130, that we almost never use. (Although I should have had it up for one close-hauled end of a leg across Lake Erie to Port Bruce in June.)DavidLady Lillie
