C42 Dutchman Sail Flaking System
Hello David. I was interested to see your posting regarding the Dutchman flaking system and the problems you have encountered. (By the way, I am a Brit living here in the USA and I've done all my sailing outside of the UK!)I have a 1997 Catalina 42 Mk II with the Dutchman fitted. I have not had the problem you have described. I am also wondering why you have to go forward to the mast to ease the topping lift. On my boat, and to my knowledge on all C42's, the topping lift is led to the cockpit via a block, through the dodger, and through the stopper under the dodger. All adjustments to the topping lift are done from the cockpit. I set the Dutchman up exactly as the manual states, adjusting the tension on each of the mono lines with the sail fully raised. When lowering, or reefing the sail I luff up, tension the topping lift, and lower the sail, or reef. I've had the boat offshore from New York to Bermuda and have had no problem in reefing without hurting the Dutchman mono lines.I am assuming that your C42 is set up pretty much standard, with the solid boom vang. Can you explain why you go forward to ease the topping lift. I'll be happy to continue to compare notes.My e-mail is mikey4@idt.netHope this helpsMichael YorkeC42, Mk II, #573, Certa CitoPort Washington, Long Island, New York
