If your sailmaker forgot to add a convex shape to the luff (eg. straight luff), the sail would set VERY flat especially in the forward panel areas of the sail between the luff and 'midcord', plus the amount of draft would be 'minimal'; also, the leech would be pointing towards the leeside and not 'straight back' when properly raised and with 'moderate to light' mainsheet tension.
How to determine the amount of this
curved luff leading edge shape in a sail: (see Note below) spread the sail on CLEAN and FLAT ground/floor. Make an accordion fold with and parallel to and the the luff section 'under' and with the accordion fold about 2-3 ft back from the leading edge. This will allow the luff edge to be laid almost totally FLAT on the floor, etc. Use your hands to get all the wrinkles and 'high spots' near the luff edge to lay FLAT and readjust the sail to get the LUFF nearly absolutely FLAT against the floor, etc. Then take a string, etc. and stretch it between the very front of the luff at the head of the sail AND at the tack of the sail, pull tight. The area that is 'in front' of the pulled tight string is the 'roach-like' shape along the luff ... and it should be matching closely to your mast bend. For a 'straight mast' the 'added' material will only be ~3/4 to 1-1/2" of added 'curve'. A sail cut for a B&R rig will have a LOT MORE convex material at the luff. Measure/mark the where maximum amount of 'extra cloth' makes its maximum 'convexity' - how much and how far above the tack, raise the sail and see/measure if the maximum 'convex-ity' closely matches with the point of maximum forward bending deflection in the set up and properly tensioned B&R mast. If there is a large discrepancy between the measurements, go to
http://www.riggingandsails.com/pdf/selden-tuning.pdf and 'retune' and correctly 'prebend' your B&R increasing or decreasing the amount of bend to better 'match' your current average sailing venue conditions.
Note: To see how to make the 'accordion fold, go to
http://www.ftp.tognews.com/GoogleFiles/Matching Luff Hollow.pdf and see the bottom (triangular-like / fig. 3) illustration -- which shows how to measure the 'luff
hollow' on a jib, which is concave in shape .... or the exact reverse/opposite to the added convex curve to the luff of a mainsail. The line A—A in the drawing is the pulled tight 'string'.
hope this helps.
