Sail cover identification help please
Mar 2, 2019
675
Oday 25 Milwaukee
My neighbors bought out an old building . The previous owner also owned a marina in Door County . She left three of these sunbrella covers behind . At first I thought they were covers for a mainsail . The longest is 20’ . There are a pair of square ears on the end . Any idea what these fit ? Any value ? Any interest ? Thanks
4,638
Hunter 46 Point Richmond, CA
Is there a ring at the top? Is there a line on it? What is the length? Length will determine the spinnaker size. No idea what the ears are for.
Mar 2, 2019
675
Oday 25 Milwaukee
No there were no rings or line. There is a small vented square on top . The bottom is open witha few reinforced holes every few feet .
The largest cover is about 20'
WayneH
Tartan 37 287 Pensacola, FL
It sounds like the control lines are missing, I think. If the reinforced holes are on opposite sides of the cover, then dual control lines would weave through the holes to the skinny end. There they would tie to a downhaul line via a pulley. It's not the easiest sock to operate but it works.
The sock I have has little rings inside the sock. And it twists and wraps and generally irritates me almost enough to buy an ATN sock.
