Sail Cleaning
Snatch
I am having trouble removing some stains from my main sail. Any ideas on a good cleaning product to use. Thanks
Feb 25, 2007
191
- - Sandusky, Ohio
Sailcare
Sorry, I can't reccommend a product buT I had good service from Sailcare in Pennsylvania. Check out their site.
Dec 2, 2003
480
Catalina C-320 Washington, NC
Zud/Naptha/TSP
Zud or Barkeepers Friend cleansers are found in the grocery store, are cheap and both contain oxalic acid as the active ingredient. This organic acid will chemically reduce rust stains and the green verdigris from bronze fittings without damaging the fabric or threads. Paste with water, soak and scrub with a soft brush. Naptha/lighter fluid will remove most grease stains. Rinse with soapy water before a final clear rinse Witch's Brew for sail cleaning. To a 2-gal bucket of water add 1 cup of boat soap, 1/4 cup of TSP powder (Tri-sodiumphosfate), 1/4 cup of Oxalic Acid powder. Apply, scrub with soft brush, rinse with fresh water, apply, scrub again, rinse, rinse, rinse, rinse and let sun dry. (courtesy of Brian Cleverly)
Snatch
Thanks
Thank you,Chris. Great info, exactly what I needed. Good Sailing Snatch
Snatch
Website
Thanks John, That is a great website that I was not aware of. thanks again Snatch
