Mild Bleach Solution
Stains and spots can be removed as follows:Rust: Soak the affected area in a 5% solution of oxalic acid dissolved in hot water. Follow this with a 2% solution of hydrochloric acid in warm water and, finally, rinse the spot well with clear water. Number adhesive: Soak the area in cleaner's benzene until the adhesive can be rubbed away with a rag. Oil, tar, and varnish: Use trichloroethylene either by itself or in solution with a liquid detergent. Mildew: Soak the affected area in a l% solution of chlorine (household bleach will do) and cold water. Rinse thoroughly and dry.I would use some liquid detergent first to clean the soiled area the best you can. Then use the bleach solution to kill any existing mold/mildew spores.
