sail cleaning
17
Oday 22 old greenwich
My sail has a bad case of block mold. Can I use an over-the-counter cleaner i.e. Fantastic w/ Bleach in order to kill the mold and clean the sail? Thanks in advance,
LLOYD
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
From advice in past threads, I am giving Oxy-Clean a try. I am doing it on Friday so if you want to hold off, I can post the results.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Accodring to Doyle's bleach is fine for use on Dacron, but should be rinsed extensively.
RECESS
Dec 20, 2003
1,509
I finished cleaning my main sail tonight. I soaked it overnight in a very weak bleach solution (1 cup added to an entire bathtub of water) I also used Palmolive Ultra. It brightened the sail and the water was a dingy shade of brown. I then ran the shower about 4 times after draining the tub flipping the sail with every rinse. I took it outside in the carport that had been power washed several times lately and rinsed it very well again. I decided to go with Super Clean as all I had left were some black marks and a little black in some spots left from mold. The Super Clean lifted it immediately. I bought a microfiber sponge so I would not be running a brush over my stitching. I was really pleased with the result and at no time felt it was harsh. I did the cleaning with Super Clean with my bare hands and no stinging. My wife was blown away at how white the sail is again. I am about to soak my Jib overnight.
Please note I do not know the long term effects of this product on sail material. I just chose to give it a shot based on the results of others.
