Justin Wolfe
This has been bugging me, and recent comments about new Hunters sailing better than Legends made me look again.If you look at the sail areas listed for new boats on this site it would appear that the sail area is much greater on new boats than the similar sized Legend boats. AND in general the boats are lighter. Sounds really good...The problem I have is that traditionally sail area on spec sheets has been just the sail area of the triangles formed by I,J,P&E. The Legend boats and the rest of the world do this, but the new Hunters, sans backstay, do not. They use the actual sail area of the sails, which because of the roach, and the slight jib overlap gives a much higher (as in 100+ sq. ft) number. Does this make for a fair comparison? Granted the new numbers are actual, but now we aren't comparing apples to apples. Sure the Legends don't have all that roach, but they have some, AND they always have an overlapping jib. The overlap in the jib should be roughly equivalent to the extra roach in the new mainsail. To me this is deceitful. If not that, it sure makes it difficult to compare a new Hunter to the rest of the world. If you're interested in the numbers simply reading the specs doesn't give you a fair answer.Also, I mentioned that the new Hunters are generally lighter than the Legends. Sounds good, except in almost every case a significant amount of the weight savings is in the BALLAST. What's the deal? Take the 320 for example, compare it to a Catalina 320, J32, and Beneteau First 33.7. I think you'll find the Hunter is about 1500 lighter than the rest, but it has 1000 lbs (25% less ballast). Someone got it wrong and someone got it right here. That is a drastically different design philosophy. So which is it? Are Catalinas, J's, and Benny's overballasted (ie too stiff)? Or?Does Hunter know something the rest of the yacht design world doesn't know?
