Saftty gear disposal
Jeffrey
I have numerous Coast Guard required hand-held flares, smoke flares and 12 gauge signal flares that are un-used but out of date. How should I dispose of them? What do you do with them? Jeffrey S/V Camille
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
Police
You local police department will take them. Being a big city, your departments probably have metal detectors and might be a little taken back if you just drop in off the street. I would call first to let them know you are coming.
Apr 11, 2006
60
- - corpus christi, tx
Keep them for back up
rockets and flares have a date stamped on them after which they are not to be used. Your boats regulation flares must be within the date. There is no regulation prohibiting you from keeping your old flares as well. The majority of old flares which appear upon visual inspection to be dry and in good condition are perfectly usable for several years after the date stamped on them. Ever crew member should know where they are kept and exactly how to use them. Make sure they read the instructions on all the flares and rockets on board. All flares do not work the same way, and at night it can be hard to decipher small writing. The spares could be used for practice drills as well.
May 31, 2004
197
Catalina 36 MK II Havre de Grace, MD
If You Practice
If you do any practice drills with the expired flares, etc, make sure you notify the proper authorities. This way they will be expecting and not think someone is indeed in trouble and needing assistance.
jimq26
Jun 5, 2004
860
Just so you get to know this site a little better-
go to the archives - type in "flare disposal" or "flares" - sit back and read the numerous past discussions on this topic.
Jeffrey
Thank you all ...
... for your responses. Thought you all might be interested, I also got an email from Commander Steven Stilleke of the US Coast Guard Search & Rescue @ Washington DC that directed me to the Boats US article that states: "To date, flares can not be recycled but special care should be taken with their disposal. Throwing flares in your household trash can cause a dangerous situation and setting off old flares can result in false distress reports. To dispose of expired flares contact your local county public works department, police or fire department. Alternatively check with a local boating education group. They often use old flares for educational purposes." Again, thank you for the info re disposal and how to better use this site... Jeffrey
stimpy
fire department
Your local fire department or rescue should be able to take them. Call first.
