Bosun's Chair Caution
If you're using a bosun's chair, one thing to check, if it has one, is the cam latch that holds the (waste?) strap that joins the two sides and that keeps you in the chair. There is a middle strap (crotch strap?) that attaches to the bottom of the chair (typically, like on the West Marine chair) that has a loop which the afore mentioned strap goes through.Anyway, on the WM chair there is a cam latch that secures the waste strap. It could be easy for this latch to inadvertantly become loose so, if you have one, consider tying it shut with some blue masking tape (the glue stickum comes off easier than duct tape).Secondly, I'd like to chime in with saying you should plan on doing a lot of the heavy lifting yourself as the pully sheave and winches for this size boat will be pushed to the limit. The winch grinder will probably have a real workout if you don't find a way to help pull a lot of the weight up yourself.Third comment: take a messenger line up with you in case you need to haul anything up.have fun!
