Do any of you with a S37 have any experience with the internals of the rudder on these boats. I recently went hard aground in some rough weather, and the boat got pounded quite a bit. Now the rudder feels very strange, and does not respond well. What it does is it seems that the first 1/4 or so turn of the wheel does nothing, then a little more wheel and it turns pretty quickly. A visual inspection in relatively clear water reveals no apparent damage. Post not obviously bent, rudder not broken or torn up. I am thinking that the rudder itself is now partially loose on the rudder post. I would appreciate hearing from anyone who knows of the internal makeup of the rudder itself. I am assuming that there are brackets or tabs welded to the post and maybe these are broken or bent. I had read on this forum that someone with a 25 had a similar problem, and they stated that the stainless rudder post on their boat had aluminum tabs/brackets welded to the stainless post, and the aluminum had deteriorated. That doesn't sound good, or likely, but if anyone knows what is inside one, please let me know. I would like to have some idea of what I'm up against, before I have to pull the boat to fix whatever is wrong.
