S2 9.2A Rudder Repair
Mar 14, 2007
88
S2 9.2A Seattle, WA
My boat is out of the water for bottom paint, inspection and repair as necessary. The rudder was found to be cracked at the top, forward end extending down for about 6" and across the top extending back about 6". Yesterday I trimmed out all the damaged area, cut back under the fiberglas skin as far as I could. Then I refilled the area with epoxy resin, milled fiber and 1/4"chopped fiber. All this 'stuff' was retained by using a piece of stiff plastic to wrap around the front of the rudder and make a mold. My question is, the interior that I had access to appears to be a mix of resin and colloidal silica. I had assumed that the interior would be a foam core. Does anyone know how the rudder was built? My repair will be stronger that the original, but I am curious about the construction.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
cant answer your question about the filler but i would like to know if you saw the tines in there welded the the rudder stem and if so were they ss or black iron and how did your welds look ...thanks woody
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Rudders are filled with foam so they are essentially neutrally buoyant. Sure you didn't see degraded foam?
Mar 14, 2007
88
S2 9.2A Seattle, WA
Woodster: I didn't need to cut so far down or aft that I uncovered the times.
BobM: Same answer, the area I cut was only around the Stainless Steel rudder post, slightly towards the rear of the rudder and the fiberglas skin top of the rudder aft about 6". Everything I saw looked like resin and filler that I assumed was colloidal silica. No foam, degraded or otherwise.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
thanks Bob i think i am going in mine a little deeper as i have rust running out the bottom where i put a weep hole to let it dry out i will try to take som pics if i do this
