Most people don't know what their boat weighs - I would not rely completely on antodotial comments and you can't rely much on manufacturers published data. My suggestion is to require the seller to provide a certified weigh ticket as part of the deal. This usually costs $10 at a public scale.
Then the solution is simple:
Step 1: Weigh the boat
Step 2: Buy a truck that is certified to tow that weight. All vehicle manufacturers are required to provide load and towing certifications for the folllowing:
Gross Combination Weight (GCW) - Total weight of a fully equipped truck and trailer with cargo, driver, and passengers, fuel, coolant, equipment, etc.
Gross Combination Weight Rating (GCWR) - Maximum allowable gross combination weight (GCW)
Gross Trailer Weight (GTW) - The weight of the trailer plus all the cargo in it. This is measured by putting a fully loaded trailer on a scale.
Gross Trailer Weight Rating (GTWR) - Maximum allowable weight of the trailer, plus its cargo.
Gross Vehicle Weight (GVW) - The total weight of the tow vehicle, including driver, passengers, and any special equipment (options, accessories and upfitted equipment), cargo, fuel, collant, etc.
Gross Vehicle Weight Rating (GVWR) - The maximum allowable total wieght of the tow vehicle, including driver, passengers, any special equipment (options, accessories and upfitted equipment), cargo, fuel, collant, etc.
If you want to explore this subject more go to this link. There is lots of info that should help.
http://h260.com/travel/travel.html
