New member/sailer here and have a question thanks in advance for any help! My girlfriend and I just made a fairly rushed purchase of a 1978 S2 7.3 shoal draft, overall she seems pretty solid(no soft spots on deck,bilge is dry, electronics seem to be in working order.) Came with a good running 5hp honda 4 stroke. My main areas of concern is a thru hull below the water line that seems to go to nothing, I don't really see a need for it so I plan to just remove it and glass over it next month(going to pull the boat do a bottom job, and paint the top side.) While she's out of the water I would like to go ahead and rebuild all the hardware/seals for the rudder.(is there a source for these or will I have to get them machined?) Also I'm going to attach pictures(if I can figure it out.) Of the starboard side bulkhead, it feels very solid and there is little to no flex on it when pulled pulled side to side but at the bottom it appears to be separating from the hull. We are mechanically inclined and can do all our own work, guessing this is a pretty straight forward procedure? We're going to have to sail it a couple miles to get it to the boat yard we're using, I feel like it's solid enough to make it any thoughts? Thanks again and pictures should be attached.
