Internal Cable slap
Coax runs internally in my mast for the VHF and cell antennas. The previous owner is an "antenna guy" - he really understands them well.I love having the antennas up high, but I am sometimes bothered by the coax slapping inside the mast in an anchorage.I hope to remedy this soon, I have two ideas, I'm not sure which one I'll try first. One is to slide some pieces of foam into the mast to hold the cables taught. A piece at the top and the bottom.The other is to put wire-ties on the wires and leave the tails on them. Hopefully the plastic ties will help to suspend the wires in the mast and give me the seperation I need from the walls of the mast to cut down on the slap. I was thinking that I would need to space them out about every 4 feet or so and I would need to put three or four wire ties at each point, each tail facing a different direction. If I use three, each tail will be 120 degrees from the next one, if four wire ties, the tails will point out at 90 degrees from each other.Any comments?Geof
