M mikeone . Oct 24, 2010 5 oday 322 glencove Mar 31, 2014 #1 anyone clean running gear with rydlyme, and does it work?
M mitiempo . Sep 28, 2008 922 Canadian Sailcraft CS27 Victoria B.C. Apr 1, 2014 #2 Its best use is to clean the cooling passages of an engine. And yes it works, this is what it is formulated for. Is this what you were planning on using it for?
ggrizzard . May 27, 2004 2,059 Hunter 30_74-83 Ponce Inlet FL Apr 1, 2014 #3 I think the OP means sheets and halyards. Then again it could be struts, chains and shafts! Nike kicks, sports bras and jogging shorts maybe?
