RUSTED OUTBOARD GAS TANK
12
- - CHAUTAQUA LAKE ,NY
My 5hp,1987 Nissan outboard has a severe rust problem inside the gas tank. I've looked into replacing it. They make a retrofit plastic replacement tank for $180 however, I found a sealer (see link) that seems to fix the problem at a fraction of the cost. Has anyone use this product by Caswell Inc? How have other sailers out their solved this problem? The engine runs like a top other wise, but I have to keep cleaning out the filter screen. Any comment? Thanks
Benny
$180? Get a plastic tank at walmart for
about $20. Add a fitting to fit your connecting hose for another $14 and you will be in business. They come in 3 or 6 gallons size. I just bought one to extend the run time of our Honda generator. I happened to use Nissan fittings as they were the least expensive.
