Rust
alibi
Sep 12, 2007
14
- - Atlantic Highlands NJ
My keel bolts were mildly rusted as I noticed while inspecting the bildge pump. I sanded them to a clean shine but I am not sure what to coat them with for protetion.I imagine rust resistant paint would not work.any suggestons would be helpfull.
Feb 6, 1998
11,772
What are they made of ..
is the first question? If they are Stainless cover them with NOTHING as you may only make it worse!!!!
Jun 19, 2004
512
Catalina 387 Hull # 24 Port Charlotte, Florida
What about putting
some Ospho on them Maine Sail? Would that hurt? It is supposed to convert Iron Oxide (rust) to Iron Phosphate and stop/prevent further oxidation. Maybe just cleaning them up really good with a lot WD 40 might help. It is supposed to act as a good preservative.
RichH
Feb 14, 2005
4,773
Absolutely NO on "ospho" .....
Dry them, a wee bit of oil... but NO ospho. If intergranular corrosion has begun (in the at the roots of the threads, etc.) Ospho or any other 'acid' will make it WORSE. A thin coat of oil or a thing coat of wax is air-permeable; the 'best' is 'dry'. If you see a lot of 'rust bloom' at the base of the nuts/washers, then consider in the near-term future to drop the keel and 'inspect the bolts'.
