Doug Margison
The epoxy barrier coat on my 91 H30 keel has chipped off in areas exposing bare iron which is starting to rust. At this point it is very minor but I want to fix it. I was thinking of removing the bottom paint on the keel with paint remover, then power sanding the keel with heavy grit paper and applying new barrier coat over the entire keel. Is this the right fix or is there a better way. has any one else had this problem. Any cautions?Regards,Doug MargisonSV Mokum II
