Rust on Keel of 38 Hunter (2008, bought new in 2010)
Dec 31, 2016
319
Beneteau Oceanis 351 Charlottetown
Also, if in the water and you can't get under to see it, check your keel bolts, if they are bolts, it's cast iron, studs with nuts, it's lead.
Dan_Y
Oct 13, 2008
519
Hunter 36 Hampton
Our '08 36 has a lead keel. Our '91 h30 had iron. When we hauled for bottom paint i had the yard wire wheel off the rust areas then they applied a rust neutralizer like phosphoric acid (Ospho), then epoxy coat then fare over any big pits and bottom paint.
