running water
1
caliber 47' atlantis yacht club
I have Jabsco Quiet-flush Electric Heads on my Caliber sailboat. After flushing one of the heads, the water continued to run into the bowl? If I turned off the water pressure the flow stopped. When I turn the pressure on again, the water started to flow into the bowl again. What needs to be replaced or repaired? Can I do it myself?
Dec 2, 1997
9,011
- - LIttle Rock
Sounds like a failed solenoid valve
Replacing it is a 10 minute job that you can--SHOULD--be able to do yourself.
Give Jabsco customer service a call on Monday...direct line is 978-282-5227
