Hi Everyone,
Just re-rigging the Vega now. I never saw the boat rigged because it was purchased on the hard with the mast down. I'm looking for clues and ideas on both the boom vang and downhaul set-ups. I can see that these lines connect to the stainless mast base, but I'm not sure what line lengths and mechanical advantage ratios are required?
Also, everything looks to be pretty much stock on this series one Vega, with the boom "floating" in it's mast track. I'm guessing the downhaul is used to tension the luff once the sail is raised? I've also noticed that some Vegas use a system where the main halyard is run back to a winch on the cabin top. I like this idea so would be keen to implement it at some time in the future. Any cons with this kind of setup?
Cheers - Jeff.
Cheers - Jeff.
