I recently purchased a 1997 Hunter 340 which is absolutely the best boat I've ever owned - not the largest, but the best. However, all of the running rigging, halyards, sheets, etc. are in very bad shape and needs replacing. Instead of going through the usual way of determining the lengths of each, is there a Hunter 340 owner out there that has recently done this and can share the lengths of line for each of the following: - Jib Halyard - Main Halyard - Jib Sheet - Main sheet - 1st reef point (main) - 2nd reef point (main) - Mainsail travelerI'd appreciate any info you can provide: rwpoole@comcast.net
