Marine grade primary wire
Bill,For this application, I would use marine grade primary wire with waterproof heat shrink type connnectors. The size, or gauge, of the wire required will depend on the amps required by the radio and pumps and the distance each is away from the battery (to and from round trip = distance). A good reference is the Electrical section of the West Marine Master Catalog. Page 552 will provide guidance on the size of the wire to use. Also, be sure that each circuit has the correct size/type fuse installed to protect the equipment from short circuits, etc.
