P
Pete
I'm installing a new electrical panel on my H22. The original panel was disconnected from the wiring so I had to trace down all the wiring to the lights which I now have identified. The original panel had 4 circuits: Cabin Lights, Running Lights and Steaming Lights. There was also a space for an Anchor Light which was not used. I just got a H22 manual from Hunter which identifies the the wiring but uses different terms for them namely the exterior lights. The manual refers to Bow & Stern lights, Mast Light for the exterior lights. Please bear with me as I'm new to sailing and want to know which lights are the Running Lights and Steaming Lights. I had just assumed all exterior light would be on when under sail. I'd like to know how to group these lights properly when I connect the new electrical panel. Also would like to know what size wire to run from the battery to the new electrical panel. My new 6 circuit panel has male clip type terminals and from what I could see of the original wiring it seemed like a #4 wire was used to connect to the old panel but can't see how I could do this with a small male terminal on my new panel. Thanks for any suggestions.Pete
