I have a 1991 33.5 Hunter that I am trying to replace the wire for a Raymarine ST60 wind transducer that runs up the mast. I want to replace it with the mast in place on the boat. I have run into a nunber of problems.
#1) the compression post on this boat is inside the wall of the shower and the only access to the top where the wires for the lights and transducer are is through a small access port in the ceiling of the fiberglass shower stall. #2) The wires are run through a hole abou 3/4" in dia. in the side of the compression post near the top. I have tried to pull the transducer wire from on top the masthead and from the compression post and I can not seem to move the wire either way. I can't tell if the wire is secured to somthing inside the mast or if the wire got pinched while the mast was being installed.
Any ideas?
Any ideas?
