I just picked up a new Rule Super Switch to replace a defective switch. After opening the package, I noticed that the two wires for the new unit are the same color. Does it make any difference which wire is connected to which wire of the terminal block located above the switch, or is there an easy way to distinguish which is the power lead and which is the ground?
